Simple While Loop 1
chrismoore2
I have been beating my head against a wall on something so simple. Will someone put me out of my misery please
Attached is the simple sheet. Please tell me where I am going so wrong.
I couldn't see anything wrong. Then again, I couldn't see anything. Double check your file that you posted.
Well, now I am home and dont have the file.
SS: |h <-- 1
|b <-- 1
|Sa < -- b + h
| while Sa ≤ 10
| h <-- h + 1
|return h
the program says basically i have an infinite loop. dont get it
I have done it without the return statement as well and get the same answer. I should get ss = 9
any ideas?
It seems that your loop increases h, but does not calculate Sa in the loop... My guess is that you should put Sa <-- b+h in the while loop, and then the loop will not be infinite. HTH
Tried changing the inequality sign
SS: |h <-- 1
|b <-- 1
| while Sa < 10
|Sa < -- b + h
|h <-- h + 1
|return h
ss = 10
still should be 9
No, it shouldn't be 9- when Sa is 9, it's still <10 so the loop gets executed one more time. Condition should be Sa<9.
Hmmm... I get what you are saying. The example was a simplistic situation for what I am really trying to calculate. I attached the mathcad and a pdf just in case. Am I not passing the arguments correctly? I have done other loops without a problem, cannot see why this one is not okay.
Look at the help for the While command. While goes until condition is met. If you are looking for a specific number of loops use the For loop command. It seems the While command start counting from zero and not from one.
yea, did that, and all the other internet searches I could, to no avail. The while command can start from any point, and I have no idea how many iterations it will take to get to my result, hense the reason for using the while loop
I have ver. 13, so I couldn't load your .xmcd file, but from the .pdf file, it seems that you don't define Sa before the while loop, so it never is > 25ksi and h stays at 5 mm.
