I have a 4-20mA transmitter that I need to power up just for using the display on the unit, there's no PLC in the application. I thought 250ohms was the minimum resistance i'd have to wire between the 24VDC supply and the transmitter to simulate the load of the PLC, but wanted to confirm if my thinking is right.
With a 24VDC supply, and a transmitter that requires at least 11VDC, would anything between 250 and 650ohms be usable? (13VDC max Vdrop/20mA=650ohms)and (5VDC min Vdrop/20mA=250ohms)
Thanks in advance
Thanks in advance
