Simulating pressure on a pump casing in SW2012 SimulationXpress
SMOKES
46
I have a pump casing that is cast in 2 parts Xpress Doesn't work for assemblies.
I have couple of question on simulation Xpress
1. The Fixture faces for bolts. Can I get away with split line to create the washer faces. I am using these to simulate the casing being mechanically held together by bolt pre load. The bolts are stiffer and and have higher yeild strength than the casing.
2. The casing is mounted to a non-rigid body is material is
stiffer than the casing is it bad practice
to used the mounting faces as fixture?
3. How do you find the critial failure areas with out sectioning the part. as express won't section. something to do with the XYZ co-ordinates in the .out file?
Material for casing Cast A351 CF8M
Material for bolts A4-80
Material for pedestal Cast A352 LCB steel
I would be grateful for any advice on FEA simulation of pump casing.
You can always join the two bodies to get one.
Create splits for the bolt loads.
Restate #2 in better English. Not quite sure what you are saying/asking.
It is Xpress after all.
TOP
CSWP, BSSE
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
