I am having trouble defining stress/displacement plots using the design study feature of SIM 2010.
The problem I am working on involves 10 different load cases applied to the same locations on the model. I am using variables for the x,y,z components of these loads (which vary from load case to load case).
It seems I must define a sensor to be able to plot stress, displacement, strain etc. for the different load cases (scenarios).
For some reason when I define a sensor for displacements (x,y,z) the plot lists the resulstant displacement. The same problem occurs when I attempt to plot stressess (membrane, bending, x, y, z) I only am able to view the von Mises stressess.
Thanks ahead of time for your help
