Imagine a single bay portal frame designed with rigid girder to column connections and base considered pinned. In reality the base is composed of a standard 4-bolt base plate connection to a concrete pedestal.
No leaner columns or additional frames for support. If the base plate is considered flexible and the frame is designed as pinned then the anchorage does not need to be designed for any moment?
In practice it seems like it must take some moment?
I understand this is a commomn assumption in multi-bay frames I am just trying to resolve some issues with invidual frames in the field.
