There has been a lot of discussion at our office over the use of single bolt connections in steel frames that we design. The two more experienced people feel quite strongly that you should not design a bolted connection that uses only one bolt. One claims that it is an erection safety issue. The other states that a single bolt connection has more prying force applied to it when the connection is in compression. Unfortunately, we cannot find any piece of code which states whether or not a single bolt connection is allowed.
Has anybody else heard about this rule? What is the background/ reasoning for not using a single bolt connection in a steel frame?
