Single-ended LVPECL to single-ended LVTTL 1
snapshotguru
1
I have a single-ended LVPECL output that I need to convert to a single-ended LVTTL output. I know they make single-ended LVPECL to differential LVPECL translators (second step is to connect this to a differential LVPECL to single-ended LVTTL translator), but I want to skip this step and use a differential LVPECL to single-ended LVTTL translator. Can I connect the single-ended LVPECL output to the P-side input and tie the N-side input to ground of the differential LVPECL to single-ended LVTTL translator?
If you want to go single ended LVPECL to single ended LVTTL, I would run the LVPECL through a comparator. Tie Vcc to 3.3V, Vee to 0V, the signal to V+, and a 2V reference to V-. The output should be LVTTL.
