rockman7892
- Apr 7, 2008
- 1,172
I have an application where a 4.16kV MV MCC feeds several 2-Speed 450hp/900hp motors pump motors. These motors currently have motor speed controlled via 2 seperate contactors with a seperate set of CT's and relays associated with each contactor (high speed & low speed).
The existing relays are older electromechanical type relays that we are looking to replace with new digital relays. I'm wondering if its possible to replace the (2) separate electromechanical relays with a single digital relay that can protect both the motor for both high and low speed applications? From what I see most motor protection relays only have a single CT input so would potentially need to parallel CT's so that the relay can see current from either contractor depending on what speed the motor is running at?
Were planning to use GE 869 relay as I now understand the 369 version of GE motor protection relay is now obsolete.
