Hi all,
My original motor used was a 1HP, 1725RPM, 6.8A ODP motor powering a squirrel cage type fan. To increase vacuum in our system, we swapped to a 1 1/2 HP, 3450RPM, 9.0A unit.
It was not known that the available voltage was at 198VAC, and as a result, spoiled the new motor. I added a boost transformer (.25VA) and have since, brought it to 226VAC.
The question is: how sensitive to substandard voltages are to these industrial motors, and will the 226VAC be enough to power the new motor once repaired? The 1HP motor did not overheat while running around 198VAC and its nameplate rating is also 230VAC. Thanks for any help.
Paul
Paul
