I run three small conveyors with 0.18 kW 3phase motors. Two of them run from single phase supplies through an inverter (0.75kW), providing variable speed. The new third conveyor runs on 3 phase directly.
I would like to run the new third conveyor from one of the inverters. I recall that it was necessary to change between Y and Delta connection when I first had the inverters installed on the other 2 conveyors.
Can somebody explain which wiring configuration is necessary and whether is is always possible to configure a 3 phase motor in either configuration? The new conveyor is a totally enclosed unit with no terminal block to view.
