tpc
Military
- Oct 4, 2000
- 1
Is there a phase difference in the signals on two wires connected to one leg of a delta configuration 115 Vac 60 Hz power source? What should be measured across the two wires? What should be measured from each wire to ground? [sig][/sig]
