nightfox1925
- Apr 3, 2006
- 567
Hi folks, I came across a question of having two single phase transformers used to develop a three phase output. I thought they are going to use 2 - 2-winding transformers and connect them in Vee-vee arrangement. It came out that they are planning to use two 230VAC single phase VARIACs. I am aware that these single phase VARIAcs are actually auto-transformers (with input + common). They are planning to connect the "output common" of VARIAC 1 to the line output of VARIAC 2 (like a Vee-vee connection). I think this will not work out since it would develop unacceptable voltage unbalance which would draw high current on one of the phases and it might fry up the VARIACs as well.
Given the situation, is there any possible connections that I am not aware of?
