In a delta-wye 33/11kV system, what will be the imbalance current detected by the 11kV substation relay in the event one of the downstream protective device operated on single-pole tripping ? Say the load current is 60A, is the relay seeing 40A (i.e.{60+60}/3) when one phase is out, and 20A (i.e. 60/3) when two phases is out as imbalance current ? Will the imbalance current treated as "earth fault" current by the relay ? Any simple formulae to calculate ? Thanks.
