CuriousElectron
- Jun 24, 2017
- 191
Hi All,
For differential protection, are there any concerns with using one set of CT's having a single ratio and the other set of CT's multi-ratio?
I don't believe that should be a problem, as long as the same ratios are wired up to the relay.
Multi-ratio gives us more flexibility, but from protection stand-point, is single-ratio preferred over a multi-ratio units?
Thanks,
EE
Thanks,
EE
