SplashMan2
Agricultural
- Mar 6, 2012
- 5
Can you help me please,
I keep being told that 'single size stone backfill is self-compacting'. Do they mean 'single size backfill requires no compaction', is there a subtle difference between the two phrases?
What I specifically need to know is that if the surround material is "clean, single size angular granular material from within the range 20mm to 70mm", what settlement is there likely to be, I need to traffic over it.
If the installation (perforated pipe, wrapped in geotextile) is within the single size material, within a prepared trench, does the backfill 'compact' in a way that minimizes settlement?
Thank you.
Thank you.
