ren_
Chemical
- Nov 14, 2016
- 23
Hi
I'm working with a float siphon to discharge water into a wetland. the siphon is reaching its drawback height of 0.44m but is not discharging as per design (11 times) its only discharging once per day. I'm wondering what the problem could be. A float siphon is a type of siphon that works on buoyancy principle, when water incoming into the siphon chamber reaches a certain height 0.44m (drawback height)the water exerts a force on the siphon and forces it fall back thereby drawing water in. for a further description of how the siphon works please view the attached file.
Data
Average discharge Ǭ = 0.0351m3/s
Pipe diameter = 110mm
Water viscosity 1*10-3 kg/ms
Density of water = 1*103 kg/m3
Roughness height e for PVC = 0.0015mm
Acceleration due to gravity =9.81m/s2
Area of the siphon chamber 2.6m by 3m
Data
