phamENG
- Feb 6, 2015
- 7,519
Curious about how others are handling this. I've seen a lot of drawings that have a generic header schedule with sizes based on width of opening. Presumably, the worst case supported joist span is selected and a header is selected for each opening width. This lends itself well to exterior headers so you can also define king studs and sills (which are based primarily on area). More than likely it's a typical schedule that just gets dropped on drawings without much consideration for openings less than 6' wide. The other option is to size each header individually.
I go with the latter option. It's time consuming and monotonous. But a lot of the houses I do are custom with widely varying joist spans and often have openings that don't align. So to do the first option, I'd have to size the 3' wide headers in non bearing walls the same as the 3' wide header transferring the reaction of the jack studs above carrying a 12' wide header. I went for a hybrid once - "Refer to schedule for header sizes UON" - that turned into a mess and I'll never do it again (never a good thing when they miss the note saying to use 3 LVLs and put in a triple 2x8 per the schedule...)
How are other residential structural engineers doing it?
