Dear All,
In some application we deploy dedicated plant air supply from air compressor packages for use as utility cleaning stations such as purging equipment. This non-critical supply can be fed directly after the air compressor and upstream the dryer package. In this case, is there any requirement to consider sizing this buffer plant air receiver vessel for the time gap from the moment one compressor stops until another one starts (loading/unloading) i.e. 5 minutes?
Please note that another dedicated instrument air receiver vessel located downstream the dryer package which is sized for the 20 minutes for peak design dry instrument air demand (critical).
I believe the final critical receiver vessel is adequate to absorb the pressure fluctuations in case of loading and unloading and there is no requirement to oversize the plant air receiver vessel for one compressor capacity loading/unloading for 5 minutes.
Appreciate your design views
