nancymarilyn1
Chemical
THE SCENARIO FOR SIZING A PSV TO PROTECT A TANK WAS A HEAT EXCHANGER SPLIT TUBE RUPTURE. THE TUBE SIDE HAS MEDIUM PRESSURE STEAM WHICH WILL BE RELEASED TO A TANK FULL OF LIQUID SOLVENT. THE PSV TO PROTECT THE TANK WAS SIZED USING API 520 GAS/VAPOR EQUATION (6) SECTION 5.6.3.1 FOR CRITICAL FLOW. THE PROPERTIES USED WERE THAT OF STEAM. MY QUESTION IS : THE PSV SHOULD HAVE BEEN SIZED USING THE API 520 EQUATION (25) SECTION FOR SIZING STEAM RELEIF AT CRITICAL FLOW CONDITIONS EQUATION (25)SECTION 5.7.1.
