erk1313
- Sep 30, 2009
- 26
I need to size a valve to relieve air from a pressurized tank to drop pressure from 16psia to 14.76psia within 5 seconds. As the outlet pressure is greater than .5283 of the inlet pressure, this will occur as non-choked (i.e. sub-critical) flow. (Note that specification is not critical to safety). Is the following equation the correct approach? If so, how can I estimate the Expansion Factor (Y) if I don't know the Pressure Drop Ratio (Xt)?
From ISA specification for Compressible Gas Flow (EQ 11a) and summarized in this manufacturer brief:
Cv: flow coefficient
q: Volumetric Flow (SCFH)
N9 = 7320; conversion constant assumes units SCFH, PSIA, and R temperature
Fp = 1; pipe geometry factor without reducers
p1: inlet pressure
Y = 1 - x/(3*Fk*Xt); expansion factor
.....Fk = 1; Ratio of Specific Heats (assume air)
.....Xt: Pressure drop ratio factor (huh?)
M = 28.97; dry air
T1: inlet temperature (R)
Z = 1: Compressibility factor (assume air at standard T and P)
x = (P1-P2)/P1; ratio of pressure drop
I assume I can iterate through the equation to find the inlet pressure drop over time.
Thanks in advance for your help.
p1: inlet pressure
M = 28.97; dry air
