Sep 5, 2013 #1 Walterke Industrial Jun 22, 2011 451 0 0 BE What's the best practice way to make a sketch line visible on a flat pattern? I want a line on there which will be used for engraving. NX 7.5.5.4 with Teamcenter 8 on win7 64 Intel Xeon @3.2GHz 8GB RAM Nvidia Quadro 2000
Sep 5, 2013 1 #2 kapmnit123 Mechanical Nov 10, 2011 538 0 0 IN Hi, You can select the supporting curves while doing the flat pattern itself (sorry i have not checked it in NX7.5 though but you can check). I am attaching an image herewith. Best Regards Kapil Sharma http://files.engineering.com/getfile.aspx?folder=78f7102b-9e8d-41ad-8cde-1c46b87dbb16&file=flat.jpg Upvote 0 Downvote
Sep 5, 2013 Thread starter #3 Walterke Industrial Jun 22, 2011 451 0 0 BE Thanks man that's exactly what I was looking for. One more question: Where can I change the line color? The supplier wants us to color engraving lines yellow. NX 7.5.5.4 with Teamcenter 8 on win7 64 Intel Xeon @3.2GHz 8GB RAM Nvidia Quadro 2000 Upvote 0 Downvote
Sep 5, 2013 Thread starter #4 Walterke Industrial Jun 22, 2011 451 0 0 BE Never mind, I found where to change it. If you go to the flat pattern style, under the tab "flat pattern" you have to change the color of "added top" NX 7.5.5.4 with Teamcenter 8 on win7 64 Intel Xeon @3.2GHz 8GB RAM Nvidia Quadro 2000 Upvote 0 Downvote
