dutchfisher2005
Aerospace
I'm designing a two stroke cylinder. I'm trying to sketch the exhaust port and duct. I'm finding it difficult to sketch the outline of the port onto the cylinder wall and then extrude cut the duct. I have tried a 3D sketch on a plane at both the angle of the duct (20 degress from Horiz) and front plane. However then i try the extrude cut the edges of the port turn up at the surface of the cylinder wall. I want the top of the port flat as in the sketch.
Not sure if i'm going about this the right way.
Using SW 2008 Sp5
Using SW 2008 Sp5
