bnickeson
- Apr 7, 2009
- 81
We are starting to see more jurisdictions go to more recent energy conservation codes which now require rigid insulation to pass between the perimeter edge of the slab-on-grade and the perimeter concrete stem wall. Prior to this, we always just placed a 1/2" expansion joint between the edge of the slab and the stem wall (or CMU as the case may be) and called it good. But the new energy codes require a very awkward detail in our area of the country where 2" of rigid insulation must be placed between the slab and perimeter wall. I am concerned that the natural shrinkage of the concrete slab will cause it to pull away from the rigid insulation and leave a gap between the two. The building I'm working on now has a 130'x200' reinforced slab-on-grade with no sawcut joints so the shrinkage could be significant. Am I correct in worrying about this detail around the perimeter? Does anyone have any experience with this and have any recommendations on a proper perimeter detail? I suppose I could place a 1/2" expansion joint between the insulation and slab edge, but I've never seen that done before.
This energy code requirement is proving to be quite the pain and was clearly not written by anyone with any practical construction experience.
