A reinforced concrete wall is poured, allowed to cure, then a reinforced concrete floor slab is poured. The rebar in the slab must be joined to the rebar in the wall. If protruding bars need to be avoided, what methods may be used to join the bars? I have already considered
1) Couplers recessed or embedded in the wall
2) Covered pre-bent bars
Can anyone suggest other options?
