Slide Rail/Slide Bearing Type
LukeChavez
3
Hello there,
I have been looking far and wide for this type of bearing/rail system that I have seen before but can't figure out what it is called to search it on the web and order it. Basically it is a curved square tube with a smaller curved square tube inside of it which slides in and out. I would assume it has ball bearings. I need this slide rail to open the lid on a cabinet up and back. I have attached a sketch of what it should look like. Any help is much appreciated.
 http://files.engineering.com/getfile.aspx?folder=de7074e9-ff9c-46fa-98a8-5bd3a20c0dee&file=Type_of_Hinge.idw
idw file format? Perhaps pdf or screen capture jpeg?
TTFN
faq731-376
7ofakss
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
Can't open your file. Are you talking about a hidden hinge?
Jboggs,
Maybe a problem with your viewer? It opened ok for me.
Basically a rectangular section bar sliding inside a similar-shaped tube, but with the whole thing curved into a quadrant shape.
These hinges provide the same motion in a different shape: Southco. It looks like they are specifically for applications like cabinet doors, would they work for you?
