If I have two mating baseplates with A490 bolts forming the base of a cantilever which I want to shim, is that allowable? I have four bolts approx 17" apart in a square pattern, and I want to shim each of the four bolts independently so that I can correct for rotational misalignment of the underlying structure. The may be approximately 1 degree of taper between the baseplate from the cantilever and the substrate baseplate. The shims for each bolt not be tapered, so would not be sitting quite hard against the baseplate.
