Ralph2
Industrial
- May 3, 2002
- 345
I am trying to find some "slow" speed balance specifications.. It "seems" to me that the standard ISO or API specs are perhaps not that valid for rotors in the 100 RPM or lower speed ranges.
One can "validate" (to a degree)by doing some math and calculating what kind of actual forces are developed at operating speeds at various balance specifications. However the formula I use .062 x (N/1000)^2 x W (in grams) x distance (in inches)= a result in pounds of force.. is not totally valid (I suspect) for ALL speed ranges. When used for a rotor rotating at 5 RPM for example the value does not make that much sense.
On a horizontal rotor I use as a minimum a balance that will prevent the rotor from finding its own heavy spot.. typically on our Schenck HB5 setup this works out to a static API 4W/N calculation... however this is more of a safety generated specification than a operational one.
The rotor that has initiated this question is a vertical application, 16 foot shaft turning a impeller / agitator at 145 RPM with combined weight of 3600 pounds (1600 & 2000). So.. my "safety" induced spec is not required and need to justify an operational one... Anyone with any thoughts??
This is a bit of an ongoing job.. and so far we (I) have picked a ISO 1940 spec of G16 for the impeller and G6.3 for the shaft. Still, that leaves 38KG.in of unbalance in the impeller when I do the standard math
Thanks for your time
