Slower graphic performance with visualization mode than design mode?
jowr
Automotive
Mar 5, 2014
9
SE
We are experiencing the strangest thing. When using Catia and Smarteam (Catia set to work with cache system) we get slower graphic performance with visualization mode then with design mode. Of course converting the complete assy from vis to design mode takes some time but graphic performance then gets better. Going back to vis-mode one again gives slower performance again.
One other strange thing (might be connected to above) is that in the folder that I have set to "Path to local cache" in Catia I get no cgr-files.
In the local work directory for smarteam I get cgr-files but they are dated from 2017, probably from when the original files was made.
Anyone with ideas that could solve this? Could it be any conflict with both smarteam and catia trying to create cgrs?
Im not the only one at the company experiencing this strange behaviour.
Best regards
JOWR
Compare your graphic card driver to other machines(assuming everyone has the same hardware). sometimes even the latest driver will yield a bad result. On a previous desktop, I had to use a driver that was 5 versions old in order to get everything running smoothly.
