jritz
- Apr 23, 2012
- 12
We have a hydaulic circuit with a single acting hydraulic cylinder (spring return) that moves against some resistance for a few inches - then is allowed to return via the spring. We want to slow down the outward movement of the cylinder when under pressure. We put a needle valve into the pressure circuit - but even when nearly closed , it does not slow the advancement of the cylinder. What do we need to do to make the cylinder movement slower and be able to vary the speed of the cylinder???
Thank You.
Thank You.
