What type of pump or system can be used to slurrify dry sand that is not at the bottom of a pond (as in a typical dredging operation). Is there such a thing as a pump that has some type of water jet(s) near the intake to assist in getting sands into suspension before pumping. I was hoping to simply dig a sump into the sand and then spray water to continue to feed the sump with more sand.
thanks,
thanks,
