I am putting together a small frame for a motor, which has sent me down a rabbit hole on resonance and frequency.
The frame is a platform 3' high x 2' square for a centrifugal motor. According to manufacturer info, the motor is approximately 18500 RPM (seems high but I am not a mechanical engineer). Typically when I do motor or pump bases, they are on a foundation and I can size the mass appropriately using the mass of the pump. In this instance, I am trying to design the frame so we don't have resonance or vibration issues and obviously I can't match the mass of a concrete foundation.
For something this small (with rubber vibration isolators) is this even something usually considered? Is the motor frequency high enough that it's not a concern? Thanks in advance for any input.
