bulkhandling
- Jul 23, 2003
- 145
For a 3" sch 80 water pipe to a high point and down hill to a low point discharge, is the downhill part pipe full or open channel? The pipe elevation is 6 ft lower than the high point and total length is about 10 ft.
As we know, for a small pipe (or tube), the pipe will always be full flow no matter what is the flow velocity or elevation difference. That is because of the siphon effect or say surface energy (pipe inner surface and water). When pipe diameter becomes bigger and bigger, the pipe will be open channel instead of siphon (full flow)if the slope is big enough (Manning Formula). My question is: how big is the pipe size for this transfer and is it independant of the velocity?
