For my wristwatch sized bugdetector
i need a very small display(module)...it should be:
a) Small as possible something like 20 mm x 10 mm x 3 mm
b) 4 characters (alphanumeric or even better dotmatrix)
c) Low voltage 5 V or better less
d) Low power draw 100mA or better much less
e) LCD or LED technique
f) Interface methods can be serial/i2C/parallel/any other
Examples of what it should display (one at the time)
VOL4
SQL8
BND3
MENU
1256
Battery power available 2.4 V/3 V (2x Nimh/Nlkaline)
If higher voltage required a DC/DC converter could be used
but should be inductor/RF-less since that might cause
interference in the receiver
Display should be a current model
Available from stock...NOT custom
Preferably more then only 1 supplier
Price max 40 Euro´s
I have done very extensive internet searches
what i found might work but each of them has it´s own
problems:
a)
Siemens/Osram/HP/Avago
SLR2016/SLO2016/SLG2016/SLY2016
Not bad...but slightly to big (hight)
Needs 5 V /110 mA (a litle to high/much)
Don´t like the (to much)separation between digits
Price OK.
b)
Osram ISD-series...same as Avago/HP (LED dotmatrix)
Almost same as a) but less higher
Very nice...but very expensive and nowhere in stock.
c) PacificDisplays 4101 (LCD serial I2C)
Almost !
...just it does only seven segment numbers
NOT alphanumeric characters.
I like to have real charactars not ugly characters
made-up from 7 digit numerical displays.
Power supply can be 2 to 6 volts at less then 200 uA !
I2C interface is perfect !
Needs a backlight diffuser ( adds 3 mm )
so total thickness a little to much again
Biggest problem...NOT Alphanumeric
Only 1 supplier in the world.
Resuming
Anyone knows of a display (module) that suits my needs ?
Thanks !
WatchJohn
VOL4
SQL8
BND3
MENU
1256
Price max 40 Euro´s
problems:
a)
Price OK.
b)
Almost !
Resuming
Thanks !
WatchJohn
