Smart Solid
gocad
Aerospace
Dec 20, 2001
1
I have a solidE built and now all of a sudden I can't pick the Smart Solid button in the part editor. Why?
Nothing works! The solid is updated.
Hi gocad
This is a classic. Your CATIA declarations (settings) are not "correct". The result is when you save your model the smart-solid-info is lost, your solid will become "unsmart".
Contact your admin to solve this. The correct declaration is:
catcmd.PROJ.BRANCH_SOLID.FILE : LOGICAL;
catcmd.PROJ.BRANCH_SOLID.FILE = TRUE;
Workaround in the meantime:
In the part editor press the right mousebutton at the lower part of the tree. Select "smart", then perform an update and your function is back...until you save your work again! Daaahh!
Kind regards, Valentin
____________________________
mailto:valentin.kaufmann@tino.net
