SMath Function 3
dik
26,065
Does anyone have a bit of code for a function to confirm that two numbers are approximately equal to each other (using a stipulated difference say 5%?) I can do it if both the numbers are +ve or both are -ve, but it fails at values near 0, where one is +ve and one is -ve. Any help appreciated.
An Excel formula that works is:
=IF(A1-A2=0,1,ABS(A1-A2)/MAX(ABS(A1),ABS(A2))<Tol)
where Tol is a named range with the tolerance.
It should be pretty easy to convert that to SMath.
Doug Jenkins
Interactive Design Services
Thanks, Doug... will take a look at it.
can you give me a hint?
MintJulep said:
That could be simplified a lot of you embraced Boolean.
I think as written is more readable, but if the function is going to be called from other routines it would certainly make things simpler to return a boolean True/False, or 1/0, rather than a text string.
One general question is whether checking the % difference compared to the larger value is always appropriate. Numbers of different sign will always differ by more than 100%, so for instance 1E-50 and -1E-50 will be found not equal.
Perhaps there should be an absolute value that will be treated as zero, or a value that will be treated as the reference if both values are smaller.
Doug Jenkins
...not called from other routines, but as a notification that the two answers are 'correct' or comparable.
Thanks, IRS... just what I wanted... I just found out that you can Windows paste directly into SMath...
To Doug's point about values straddling zero, this is a much easier question to answer if tolerance is a number rather than a percentage.
MintJulep - OK, that's neater :)
Excel version:
=ABS(A1-A2) <= (Tol * MAX(ABS(A1),ABS(A2)))
I still think we need a check for two numbers very close to zero though.
Doug Jenkins
Improved... I had modified the original in case the second arg was a zero... Fixt...
and in the program... the dimensions are all the same because I just 'cut and pasted' the variables and changed the name.
