SMath - XY Plot Region 2
Seems like there's a syntax thing going on. The input needs to be one or more nested matrices:
TTFN (ta ta for now)
Thanks very much... I don't need all the shapes... just the circle and the line.
Dik
Your solution works almost like I thought it would when you trim away things like mine... except for your double sets of brackets... maybe that's the issue. Will check.
That's what the problem was. The graph was looking for a vector value and all the vectors referenced had to be converted to a single vector... I'd have never guessed. I wish there was an explanation to the used of xyplot. Seems to be a very useful and powerful plugin.
Dik
 https://files.engineering.com/getfile.aspx?folder=c94c06de-ba0d-4f32-9b89-0fb9b50fc4cc&file=IRS_Test.sm
