waveboy
- Mar 19, 2006
- 69
You have type 1, 2 & 3 error amps for SMPS feedback compensation...
But what is the error amp called that is just a high gain inverting amp?...ie, not an integrating error amp.
Also, can you confirm, that using this (unknown name) error amplifer, there is no gaurantee in eg a Buck battery charger that you would reduce the chances of instability, by using it, instead of a type 1, 2 or 3 error amp?
