SNACK and AutoCAD
sorenfdk
Marine/Ocean
Sep 3, 2001
13
Hi everybody!
We have a problem which we hope someone can solve for us!
SNACK (which is no longer supported) can save airfoil coordinates in DXF-format. We have tried to import the coordinates in to AutoCAD 2002, which went fine, but the drawings in no way resembled an airfoil!
Where did we go wrong?
Søren Flening
CDE Danish Marine Design
I'm not familiar with SNACK, but if the program can list the points used to create the airfoil, copy the list of points from the command line (if it has one!)and paste them into the command line of AutoCAD. If you list the points in SNACK while a known point is on 0,0, then in AutoCAD draw a polyline, starting at 0,0 then paste in the list of points and this should draw the profile for you.
Hope this helps!
I have SNACK, and AutoCAD 2002. I just tried a "Save As" DXF format, and did a "DXFIN" command in AutoCad. Worked just fine.
Let me know what airfoil you need and I can save it out for you in .DWG format, if you want.
I made a simple excel file that create a dxf file from x,y and z points. If you want I can send to you this file!
Simone
Simone,
Could you please send me a copy of yor excel file that creates the dxf file?
Thanks!
projeto - projeto@clmax.com
Simone,
Could you please send me a copy of yor excel file that creates the dxf file. I need something like this urgently to help me create thousands of the same drawing with different dimensions.
Thanks!
psychic_79@hotmail.com
Hi Simone,
Another request i'm afraid, could I also have a copy of your excel file.
NMDesignsLtd@aol.com
Many thanks,
Neilmo
Simone,
Did you e-mail me a copy of your excel file. If you did, I apologise as I seem to have lost it. Any chance of another copy.
Many thanks,
Neilmo
Simone,
Could you please send me a copy of yor excel file that creates the dxf file. I need that for my class project. UAV
aerodolphin@hotmail.com
