According to B31.1 what are the size and classification limits for socket welded valves and fittings
B31.1 references both B16.11 and B16.34 ( which also references B16.11 )
B16.11 limits end at 2" for a 6000 class as no values are given for 2-1/2" class 6000
From a valve manufacture " Refer to Table 4 of B16.34, attached. The wording is tricky, but it requires that only the socket diameter, depth and end surface be to B16.11. Everything else is to be to B16.34, including wall thickness".
111.3.4 Drains and bypasses may be attached to
a fitting or valve by socket welding, provided the socket
depth, bore diameter, and shoulder thickness conform
to the requirements of ASME B16.11
If this is correct why would a socket weld valve be allowed in a service condition that a fitting would not be allowed
