Billy Joe Davis
- Aug 6, 2017
- 1
I am a System Engineer for a facility. We have an old Sodium hydroxide dissolver tank, ~200 gallons, and associated equipment. At some point the system was shut down and not properly cleaned up. The tank contains white powder, which based on its past use I believe to be Sodium hydroxide. The tank and piping are constructed of Stainless Steel and visually appear to have no outward degradation. However, many of the piping components such valves, pumps and flanges have failed. The sealing materials within these components have deteriorated and allowed leaks. As this leakage takes place the liquid the small amount of liquid evaporates and crystals are being formed.
We no longer have use for the system and I would like to D&D the entire system. How can I remove the granules from the tank safely? I cannot dissolve them in the tank because of the leaks that would occur. I thought of vacuuming out the tank, but I am not sure what type of vacuum system would filter the exhaust properly so the sodium hydroxide would not be blown out into the surrounding area.
Anyone have any experience with this type of situation?
Thanks in advance.
Thanks in advance.
