DCBII
- Apr 15, 2010
- 187
Consider a multistory structure with a basement. Assume the geotechnical engineer has given you a soil seismic load against the basement wall. That soil seismic load is resisted largely by the ground floor diaphragm at the top of the basement wall, which carries it out to the basement shear walls. How does this seismic earth force affect the vertical distribution of seismic forces? I would assume it is usually ignored when calculating the vertical distribution, and then added on afterward to the ground floor diaphragm, but I wanted to get the community's input.
Also, does the R value of the basement walls affect the seismic earth force? For example, would this force be the same in an ordinary reinforced shear wall as in a special reinforced shear wall? I would guess that most engineers just take the force at face value and don't modify it based on R.
