Soil springs
DougHole
48
When geotechnical and structural engineers talk about "Soil springs", what do they mean in the context of lateral pile analyses? is this just a p-y curve? or is it just subgrade modulus (k) or is something else. How do I come up with "soil springs"? Can I do this in LPILE and if so, how?
Dougfunny, are you sure the section is the correct one (slope stability)?.
Usually, by soil springs in your case I would construe a linear law relating lateral loading against strain, represented conceptually by a spring.
Sometimes the models are merely elastic (linear) springs, sometimes they can be elastic-plastic, with a rupture treshold calculated by active and passive resistance of pile shaft. P-Y curves might be defined non linear soil springs, where the spring softens when the loading increases, up to a treshold level (plastic yielding). As far as I know Lpile carries the classic Matlock & Reese p-y curves models, if not somthing more recent, so you can actually model lateral springs. I'm not an Lpile user so I cannot say you how, it should be straightforward though since you just choose the p-y analysis option and input the appropriate soil types, which are few and basic ones.
Hi McCoy. thanks you are right. I just realized its in the slope stability forum! thanks for the reply.
So it sounds like lateral "springs" come in various forms and a p-y curves is one type of "Spring" i.e. a non-linear one. How do you come up with linear lateral springs for a pile? is that just the same as a subgrade modulus reaction (k value)? Also, how does one come up with vertical springs for a pile. By the way, I will leave this post under "Slope Stability" for now. Sorry about posting it in the wrong place
Exactly, that would be similar to the Winkler model adopted for shallow foundations. For very small strains, the K value would be the same as the initial part of the p-y curve but a modulus secant to the p-y curve is strongly advised in operational conditions.
There are 2 kinds of vertical springs, the ones along the shaft and the one at the bottom of the pile, although in many models the whole pile is modeled as a single huge vertical spring + one huge horizontal spring. In more evolved programs the pile is modelled by finite elements, every lenght having its springs (I'm working on a model where each pile element has 3 kinds of springs, vertical, lateral horizontal springs and torsional springs. The base element carries four springs, since there is a vertical one at the base added.
Thanks so much McCoy for helping me understand "springs". Much appreciated
