ZDawg
- Dec 4, 2014
- 11
Hello all, I am modeling several PIG Traps of varying size and all require an anchor/thrust block prior to the pipeline leaving the ground. I have already modeled them, buried them, set up the fine meshes, and even gone through and re-calculated, by hand, the axial restraints and required anchor force to limit the movement of the system. My question is, can anyone briefly explain how to go from the axial soil restraint or required anchor force to the buried CAESAR model. This is my first time using CAESAR and have put in an anchor to read the forces, which came out as 1.6E6 pounds. This is not reasonable for actual construction so I am trying to set different forces in to see how the model responds, but again, if I begin just plugging in values, how do I take those and come up with an actual anchor size? I apologize if this isn't written well, I have been racking my brain for days on this.
