cmbyrd77
- Aug 4, 2010
- 79
I am designing a structural steel carport that will be supporting solar panels on the top of it, therefore I have no real diaphragm action because I am not counting on the solar panels and their connections to form any sort of lateral rigidity. I wanted to frame the purlins into the side of the man supporting members that articulate of the columns to avoid it from rolling. However, the client wants the purlins to run over the top (see attached sketch). Should I be worried about the torsional stability of the main supporting beam. I feel like the purlins framing on top will brace the top flange as long as I make the columns and their base connections. However, there's another part of me that thinks that the wind loads out on the ends of the main member won't get back to the columns without the main member rolling. The other option I thought about was just adding stiffeners at every purlin location. Thank you in advance for you help.
