hokie66
- Jul 19, 2006
- 23,117
Maybe some of you smart folks in the tech pub can explain for me the logic of placing solar panels on the roof of a house.
There are obvious advantages of centralized power generation, so why would solar be an exception? I suppose it could be because you don't have to transport solar fuel, but is that really enough reason?
Residential solar systems are expensive to buy, install, and maintain. And then, if excess power is generated which could be exported to the grid, the existing grid sometimes can't cope (according to reports I have read).
I wouldn't want panels on my roof. They have limited life, and I imagine require a bit of maintenance during that life. What happens if you need to get at the roof for maintenance? Surely all those penetrations will create some leaks.
Is this all just a political stunt inspired by greenies? Most of these schemes have government subsidies attached at the consumer end, and some have backfired. The manufacturer subsidy end seems to be dodgy as well (Solyndra).
