I will use common objects to make this a bit more easy to ask. Lets say I have a medium sized enclosure (say a box that is around 3 feet by 2 feet by 2 feet).
I have a internal heat load (given) and I also have a internal temperature that I would like to maintain (Lets say it is 135F). So I can use Q=m.Cp Delta T to determine the flow rate required to maintain the internal temperature where I want it (based off outdoor air temperatures).
If I know what the internal temperature is because I have a fan sized to maintain that temperature then I assume I can determine the heat transfer through the walls using the equation Q=UA delta T. I know what the build up of the wall is so I can determine the U and I already have Area.
That is great - and once I have my Q I can then use it to determine what the surface temperature of the outside wall will be.
The part I am not sure how to do is- how do I factor solar loading into this so as to determine what the skin temperature will be when it is solar loaded? I was told the number to use for solar loading is 355 BTU/sqft hr but I have no idea how to do this....
I am looking for some detailed instruction on how to determine the true skin temp with solar loading involved..
