Solar Sails - may not work
First off we should all be very weary when someone attempts to use Thermodynamics to explain a dynamic process. Thermodynamics at it's heart is not dynamic at all. It concerns itself with end states caring little about how any particle got to where it is. That being said Thermodynamics cannot tell us anything about momentum transfer. To understand that we must look at the problem from a dynamic situation. First, we have a sail of given mass that will be hit with particles of zero mass but finite momentum, the photons. So the laws the govern the process will be electromagnetic. So clearly the amount of force the sail experiences will be a function of both intensity and wavelength. The total force can then be obtained by integrating over the wavelengths.
As to effectiveness, the photons will exchange momentum with the sail through the processes of absoption and emission. So it comes down to a discussion of electromagnetic interactions. This is clearly beyond the scope of thermodynamic principles. Furthermore, the pressure exerted is a kinetmaic pressure (force per unit area) rather than a measurement of fluid energy.
A quick review of Jackson (3rd Edition) problem 6.11 shows the basic ideas of what is occuring. However, the implicit assumption that the sail is a perfect absorber and furthermore emits no electromagnetic energy is in question. I also believe there is an assuption that no electromagnetic energy is converted to thermal motions in the sail.
As a final note, even if only 1% of the flux of solar EM energy is converted into motional energy you still gain an order of magnitude higher acceleration that by using proton momentum exchange.
So is the light pressure effect really 1000 times greater than momentum? I assume you meant "photon momentum exchange". It's hard to get a real feel for the physical processes involved. The popular press almost always gets solar sails wrong, saying they work off the solar wind, rather than light. But even just considering "simple" photons, I guess (as this discussion shows) there's a lot going on.
Although the Cosmos 1 solar sail test suffered a launch failure last year, I was under the impression that the Soviets (or somebody) had more or less validated the basic solar sail physics just from using small sections for attitude control some years back. I didn't find anything specific about that with a quick Google search, but there is a page that notes at least some of the stuff that has flown before, including the Indian INSAT 2A & 3A:
There is also Ben Diedrich's website
Which includes a page on the physics of solar sailing
Though this doesn't really get into the light pressure vs. thermodynamics question.
• Check out my aerospace site, AeroGo []
• I also comment on technology in general, business, etc., on my blog All Things
