I am using a Transformer in solar project where my inverter will give output of 600V, I have to step up this voltage to 12.47kV system which will be connected to utility. The existing infrastructure of utility is 12.47kV delta.
I am thinking to use YNy0 transformer but not sure. Can someone explain me importance of neutral on HV and LV side of transformer when it is connected as step up specifically in solar plant.
Thanks in Advance
KS20
Thanks in Advance
KS20
