SamuelMoura
Chemical
- Jan 27, 2011
- 1
Recently i've been assigned to inspect a pipeline of medical gases in a cirurgy clinic. The medical gases involved was N2O and O2. The operation pressure of the pipeline will be alway below 7 kgf/cm2 (100 psi). Researching the correspondent technical data and norms, i've found it is recomended the so called "strong bending", "strong soldering" or "silver soldering" - wich is made with a temperature above 450°C (850°F), instead of the "weak soldering", "weak bending" or "tin soldering". My question is: what would be the effect of using this last one type of soldering?
