Solid edge console application doest make lines
andries41
EU
I made the following code with visual basic 2003 to make curves in solid edge.
The problem is that the program doest draw anything in solid edge. Every variable i got, what is read from a text file, is used. The arrays for making the curves with the BSplinecurve2d.addbypoints method are also stored.
But nothing happens, only a part window gets opened.
Anyone knows why this is?
The code is a bit long so sorry if it is getting a bit too much.
Thanks in advance.
Code:
Imports System.IO
Imports System.Runtime.InteropServices
Imports System.Collections
Module Module1
    Sub Main()
        Dim strFileName As String = "U:\pompen.prn"
        Dim objFS As New FileStream(strFileName, FileMode.Open, FileAccess.Read)
        Dim objSR As New StreamReader(objFS)
        Dim objApp As SolidEdgeFramework.Application = Nothing
        Dim objDocuments As SolidEdgeFramework.Documents = Nothing
        Dim objPart As SolidEdgePart.PartDocument = Nothing
        Dim objProfileSets As SolidEdgePart.ProfileSets = Nothing
        Dim objProfileSet As SolidEdgePart.ProfileSet = Nothing
        Dim objProfiles As SolidEdgePart.Profiles = Nothing
        Dim objProfile As SolidEdgePart.Profile = Nothing
        Dim objRefplanes As SolidEdgePart.RefPlanes = Nothing
        Dim objBspline As SolidEdgeFrameworkSupport.BSplineCurve2d = Nothing
        Dim objBsplines As SolidEdgeFrameworkSupport.BSplineCurves2d = Nothing
        Dim objLines2d As SolidEdgeFrameworkSupport.Lines2d = Nothing
        Dim objLine2d As SolidEdgeFrameworkSupport.Line2d = Nothing
        Dim strEmpRecord As String
        Dim type As String
        Dim N1 As Double
        Dim QT As Double
        Dim DW1 As Double
        Dim EQ As Double
        Dim EH As Double
        Dim DWL As Double
        Dim DHL As Double
        Dim C1 As Decimal
        Dim C2 As Decimal
        Dim C3 As Decimal
        Dim C4 As Decimal
        Dim C5 As Decimal
        Dim QFACTOR As Double
        Dim q As Double
        Dim h As Double
        Dim qx As Double
        Dim hx As Double
        Dim qa As Double
        Dim ha As Double
        Dim qeind As Double
        Dim qeind2 As Double
        Try
            'connect to a Solid Edge file.
            'Connect to a running instance of Solid Edge
            objApp = Marshal.GetActiveObject("SolidEdge.Application")
            'Get a reference to the documents collection
            objDocuments = objApp.Documents
            'Create a new part document
            objPart = objDocuments.Add("SolidEdge.PartDocument")
            'Get a reference to the profile sets collection
            objProfileSets = objPart.ProfileSets
            'Add a new profile set
            objProfileSet = objProfileSets.Add()
            'Get a reference to the profiles collection
            objProfiles = objProfileSet.Profiles
            'Get a reference to the ref planes collection
            objRefplanes = objPart.RefPlanes
            'Add a new profile
            objProfile = objProfiles.Add(objRefplanes.Item(3))
            'Get a reference to spline curve collection
            objBsplines = objProfile.BSplineCurves2d
            'Get a reference to the lines2d collection
            objLines2d = objProfile.Lines2d
            Dim nfi As Globalization.NumberFormatInfo = New Globalization.CultureInfo("en-US", False).NumberFormat
            nfi.NumberGroupSeparator = " "
            nfi.NumberDecimalSeparator = ","
            Do While objSR.Peek <> -1
                ' read the current record (line) into the variable strEmpRecord
                strEmpRecord = objSR.ReadLine
                Try
                    ' break up the record into separate variables
                    type = strEmpRecord.Substring(1, 19)
                    N1 = CDbl(strEmpRecord.Substring(20, 9))
                    QT = CDbl(strEmpRecord.Substring(30, 9))
                    DW1 = CDbl(strEmpRecord.Substring(40, 9))
                    EQ = CDbl(strEmpRecord.Substring(50, 9))
                    EH = CDbl(strEmpRecord.Substring(60, 9))
                    DHL = CDbl(strEmpRecord.Substring(70, 9))
                    DWL = CDbl(strEmpRecord.Substring(80, 9))
                    C1 = CDbl(strEmpRecord.Substring(90, 19))
                    C2 = CDbl(strEmpRecord.Substring(110, 19))
                    C3 = CDbl(strEmpRecord.Substring(130, 19))
                    C4 = CDbl(strEmpRecord.Substring(150, 19))
                    C5 = CDbl(strEmpRecord.Substring(170, 19))
                    QFACTOR = CDbl(strEmpRecord.Substring(190, 3))
                Catch ex As System.InvalidCastException
                End Try
            Loop
            'Dmax
            Dim i As Double
            Dim listofdata As New ArrayList
            For i = 0.2 To QFACTOR Step 0.1
                q = (i * QT)
                h = ((((q ^ 4) * C1) + ((q ^ 3) * C2) + ((q ^ 2) * C3) + (q * C4) + C5))
                listofdata.Add(q)
                listofdata.Add(h)
            Next
            Dim dataArray() As Double
            dataArray = DirectCast(listofdata.ToArray(GetType(Double)), Double())
            objBspline = objBsplines.AddByPoints(4, 13, dataArray)
            'Dmin
            qx = ((DWL / DW1) ^ EQ)
            hx = ((DWL / DW1) ^ EH)
            Dim listofdata2 As New ArrayList
            For i = 0.2 To 1.5 Step 0.1
                q = (i * QT)
                qa = (qx * q)
                ha = (hx * (((q ^ 4) * C1) + ((q ^ 3) * C2) + ((q ^ 2) * C3) + (q * C4) + C5))
                listofdata2.Add(qa)
                listofdata2.Add(ha)
            Next
            Dim data2Array() As Double
            data2Array = DirectCast(listofdata2.ToArray(GetType(Double)), Double())
            objBspline = objBsplines.AddByPoints(4, 13, data2Array)
            'make connection lines
            qeind = QFACTOR * QT
            qeind2 = qx * qeind
            objLine2d = objLines2d.AddBy2Points(qeind2, (hx * (((qeind2 ^ 4) * C1) + ((qeind2 ^ 3) * C2) + ((qeind2 ^ 2) * C3) + (qeind2 * C4) + C5)), qeind, (((qeind ^ 4) * C1) + ((qeind ^ 3) * C2) + ((qeind ^ 2) * C3) + (qeind * C4) + C5))
            ' Close the profile
            objProfile.End( _
                SolidEdgePart.ProfileValidationType.igProfileClosed)
        Finally
            If Not (objLine2d Is Nothing) Then
                Marshal.ReleaseComObject(objLine2d)
                objLine2d = Nothing
            End If
            If Not (objLines2d Is Nothing) Then
                Marshal.ReleaseComObject(objLines2d)
                objLines2d = Nothing
            End If
            If Not (objBspline Is Nothing) Then
                Marshal.ReleaseComObject(objBspline)
                objBspline = Nothing
            End If
            If Not (objBsplines Is Nothing) Then
                Marshal.ReleaseComObject(objBsplines)
                objBsplines = Nothing
            End If
            If Not (objRefplanes Is Nothing) Then
                Marshal.ReleaseComObject(objRefplanes)
                objRefplanes = Nothing
            End If
            If Not (objProfile Is Nothing) Then
                Marshal.ReleaseComObject(objProfile)
                objProfile = Nothing
            End If
            If Not (objProfiles Is Nothing) Then
                Marshal.ReleaseComObject(objProfiles)
                objProfiles = Nothing
            End If
            If Not (objProfileSet Is Nothing) Then
                Marshal.ReleaseComObject(objProfileSet)
                objProfileSet = Nothing
            End If
            If Not (objProfileSets Is Nothing) Then
                Marshal.ReleaseComObject(objProfileSets)
                objProfileSets = Nothing
            End If
            If Not (objPart Is Nothing) Then
                Marshal.ReleaseComObject(objPart)
                objPart = Nothing
            End If
            If Not (objDocuments Is Nothing) Then
                Marshal.ReleaseComObject(objDocuments)
                objDocuments = Nothing
            End If
            If Not (objApp Is Nothing) Then
                Marshal.ReleaseComObject(objApp)
                objApp = Nothing
            End If
        End Try
        objSR.Close()
        Console.WriteLine("")
        Console.WriteLine("Press Enter to close this window.")
        Console.ReadLine()
    End Sub
End Module
Okay i managed to make it draw my lines and curves, but the problem now is that my data is stored as meters. In solid eddge i will get really big lines and curves. Can i convert my data in visual basic to millimeters?
Also i wnat to edit my sketch, but i cant acces my sketch. And when i save th file, the lines and curves just disappear.
